Sorry if either of these have been asked before but I did search.
I was wondering if theres a bluetooth headset, but a proper stereo one that I can listen to music through? I have seen one but its like �80, is there a cheaper one?
Also, Because the p800 memory limitation is software and not hardware (as far as I have been told by reading other posts), does that mean that it is actually possible? Isn't their some way of creating software or something? or is it just impossible.
The P800 does NOT support stereo BT headsets.
About the memory limitation: theoretically possible, but you've got to go deep in to the OS, no-one managed to do so
ok thanks, so it would be a modification of the actuall system files?
Do you know if theres an adaptor to allow normal stereo headphones?
You should get a 2,5mm-to-3,5mm converter, virtually every hi-fi store has one for a few quid.
However, you can't make calls using this solution (no microphone). So you can also try this:
http://pc-mobile.net/sp8aa.htm
thanks 😊
That adaptor looks just what I want but its from the US 😞 hopefully there will be a UK version.
