transfering files from SEndo X to PC
3 replies · 1,720 views · Started 31 January 2005
When I use the File Browser in Sendo PC Connect, I am unable to locate photos that I'd taken earlier. Both the manual and Sendo Online Support say that you simply open the File Browser and that any files on the SEndo X can be transered. I've searched through ALL the folders and cannot find my photos, even though they ARE THERE, as I can view them through the phone's Photo Album app.
Am I going crazy? Am I missing something very obvious?
I appreciate that I can transer photos from the album via IR and Bluetooth, but I want to use USB to get them on my PC.
Any help greatly appreciated 😊
All the photos you've taken (and saved) are located in c:\nokia\images. To get there all you should have to do is connect your Sendo to the PC, load PC connect, click the 'Browse' button, and in the right window go to the location above.
If they are not there, and you are sure they are on the phone, you could try restarting your compter and try again, or try and re-install the Sendo X drivers and PC Connect software
So did you find them, or are they still only visable on your phone? 😊
