hi, does anyone know how to COMPLETELY uninstall bluetooth from pc? including registry and all that hidden stuff? i should have installed software b4 pluging in the bt device. any help? i want to install bt again from scratch...
uninstall bt
jeh first u have to put ur bluetooth device in an other usb-port becouse it automaticly update the bluetooth device if u install it and the update can't be removed after doing this u can just go to the control panel and go to software and than remove every thing that starts with bluetooth or sync station
