*Every* time my 9500 connects to my wifi at home, I have to input the WEP settings and tell it its 40 bit encryption.
I know I should change it, but why can't I get it to connect without this every time? What could I do to fix this? - My XDA IIS from work logs on without trying every time :con?
richardyates wrote:*Every* time my 9500 connects to my wifi at home, I have to input the WEP settings and tell it its 40 bit encryption.I know I should change it, but why can't I get it to connect without this every time? What could I do to fix this? - My XDA IIS from work logs on without trying every time :con?
Hi
If you create a new connection under control panel\connections\internet (include advanced setup). You can use this setup in both 'Messaging' for your email and the 'Web'.
Steve
Thanks - and ignore Easy WLAN I assume?
richardyates wrote:Thanks - and ignore Easy WLAN I assume?
yeah, choose the one you created.
Also, under messaging, you can create new connections and emails logons etc, here under general, hidden off page you can specify which is the default.
Sir, you are a genius! Many thanks 😊
