hi,
i've got a few maps on the memory card of my nokia 7610. i use a bluetooth device and pc suite. so when i enter E: (memory card) then there should be a map called 'System' but on my pc (with pc suite) i cant see the map. I know there is a map called 'System' because when i use a program called FExplorer on my phone i can see the system map. does any 1 knows how to show the map on my pc using bluetooth ???
how to show hidden maps on my pc with bluetooth
They are not "maps", but "directories" or "folders" (unless you actually are referring to files that contain maps of some sort).
In any case, PC Suite only allows you to see such folders that apps such as the Gallery, etc., on the phone have been fixed as to where they store files. That excludes the "System" folder (and others you can see with FExplorer on the phone).
jeh i see but is there no way ? maby a other bluetooth prog than pc suite ?
Just put your memory card into a memory card reader and using windows explorer, go to.... tools> folder options> view and then check the "show hidden files and folders" box, and then hey presto, the system folder appears.
