need sx1 software
5 replies · 3,010 views · Started 01 February 2005
is there anyone who knows a software for sx1 that lets to make changes or edit address book other than oxygen opm or siemens data suit?
Appreciates for any help!!!
akdemiris wrote:is there anyone who knows a software for sx1 that lets to make changes or edit address book other than oxygen opm or siemens data suit?
Nothing than soft u mentioned, but u can try Contacts manger or sVcard (backup/import/export)
Cheers
Get more guides and advice at:
www.symbian-freak.com
OzBert wrote:smartVcard is available at www.siemens-mobile.com/sx1 as free download (full version) for SX1, btw. - among other free full versions of games and apps.
OzBert
If you need to import contacts from an Excel like file (like a csv) you will like Contact Manager.
It's the only symbian program (note that it's a Symbian program, not a PC one) i finally managed to use to manage my address book and Import Export it!
fgpx78 wrote:If you need to import contacts from an Excel like file (like a csv) you will like Contact Manager.
Hey that's great!!! could you tell me where I can download it please.
Actually I am looking for a software which lets play with contacts and messages on pc. My previous cell phone was Cx65 and SiMoCo software is very successful and functional on that. Anyway I see other than oxygen software and siemens data suit program there is not any PC program does this.
Again appreciates if you please write what the web site is of contact manager.
akdemiris wrote:Hey that's great!!! could you tell me where I can download it please.
Contacts Manager
Contacts Manager application can export/import contacts from/to Nokia
7650/3650 using a textual file (CSV, TXT) with delimiters. The
format/protocol of the exported file is the same like in Contacts Manager
for N92xx.
As a result of export, you will get delimited CSV/TXT file in Unicode
ordered into "columns". It transfers all fields, including 'hidden' and
'special' ones. Multi-fields (repeating) are handled properly (multi-lining
is used). Fields with user-defined description, pictures and ringings are
also supported.
A file in the Contacts Manager format can be imported into Nokia 7650/3650,
Nokia 9210/9290, a sheet or database application on PC, etc.
Trial version has following restriction: only 25 contacts are
exported/imported.
Company:
AGORA plus
Home page:
http://www.communicator.cz
