I have downloaded the video capture program but cant work out how to play the videos on my phone. Can anyone help me on that.
cheers
cheers
Select Options then Record, it will then record.
Now select the file in the main screen and it will playback 😃
Nice and Simple.
You are using Hantro T-mobile?
I had worked out how to record it, but when i play it back it says no app is attached to this type of file or something like that.
hantro t-mobile????
J2theIZZO... my guess is.. he is not using the one we used... T-mobile
Im using PCAuthor
Is hantro t mobile better then?
I've never heard of that application.
Could you Zip it up and post it on here please and I'll have a play with it.
You can get Hantro Video program by searching the forum.
