anyone here has tried it out....is there any good sites that review it??
I am deciding wether to get the Moto HS850 or Jabra bt800 cuase of BT 1.2..
anyone here has the moto hs850 headset...i heard its not that loud...
I have the BT800 + Nokia 6630 and it works damn good (got a faulty one at first but vodafone store changed it without a hazzle) the volume is really good ( i tried a Nokia hs 4w first and that sucked bigtime) the only thing with BT800 that could be better is the fitting to the ear its not very snuggly fitting.
why cuase its uncomfortable or it doents fit in the ear right...
Yes , it doesnt fit very well in the ear (different people have different ears..so i guess its vary alot) like the Jabra 250 you kinda like plug a rubber thingy into the ear but the 800 is more like a , remember the first walkman earphones? if you remove the rubberfoam then thats what the 800 earphon looks like (more or less)
does anyone know if nokia 6680 supports bt800 caller id.
looked on pdf and only shows 6600 which it says doesn't
thanks
yes i've tried my BT800 with the Nokia 6680 and works exactly as good as on the 6630....callerid and all ( remember that callerid is jusst the telephone number on the headset, NOT the names.)
Caller id works indeed, but the call list function of the BT800 doesn't work on most Nokia phones........
The BT800 can store up to 10 phone numbers of received phone calls and from the call list you can select a number to call back. The problem with most Nokia phones is that the "+" from the phone number isn't transfered to the BT800 and when you select a number to call back from the call list on the BT800 the number is dialed without the "+" resulting in a not working dialed number.
Jabra support told me that the call list problem is a problem with the Nokia phones not sending the phonenumber correctly. Other brand phones doesn't have this problem.
Nokia support told me they couldn't solve it cause it wasn't a Nokia headset 😡
So I asked to have a firmware update to solve the problem...... Let's see if they will do that for my 6630.....
So let us all call the Nokia support care line and maybe they will update the firmware 😉
did any one know why Jabra BT800 not showing the caller name but only the number with Nokia N93
thanks
