i have a efilemanager,
and i think it is possible to remove the files that i dont want,
is it okay to remove them??
ex. some midi file that i dont want
is it okay to remove files that i dont want??
Well if you are talking about midi files you have put into the phone, then go ahead I would say. But if you are talking about midi files of applications like bounce etc, then I dont know ? The application may behave strangely (crash!!) if the required file is not there.. then again it depends a lot on the application. If you want to try risking it try renaming the file, run the app, if there is no problem then you are home clear.. (maybe disabling sound will remove the attempt to load the midi)
what about the midis that comes with the phone?
I dont think you can delete those midi files, they are in ROM. 😞
ic.. thanks,,
is it posible to change the font style??
No, you cannot change style or size to my knowledge. :cry:
I removed that picture game with seleQ. No problems, but the icon for the game stay's but the game itself is gone.
got me another extra 20kb..woohooo.... ahum..
I don't think that's the full game, you just removed a small part of it.
The sis file is kept in the Z: drive along with Snake
I'd love to get rid of both of them, there a complete waste of space!!
