Hi all
just wondering had anyone else this problem with headphones, says enhancement not supported. how do i change it so it is??
Hi all
Which headphones, exactly (manufacturer and model)?
The Nokia headsets supported by the 6630 are listed here:
http://www.nokia.com/nokia/0,8764,58715,00.html
N/A wrote:Which headphones, exactly (manufacturer and model)?The Nokia headsets supported by the 6630 are listed here:
Its the Nokia HDS-3. It worked fine last week, when i got the phone and was just tryin it out last nite and i get that message. in the meantime i have got the wireless headset working. would that make any difference???
Shouldn't make a difference, if the wireless (Bluetooth) headset is not connected when you try to connect the HDS-3 (actually, I think then the wireless headset is just disconnected automatically).
Perhaps the headset is broken (does it work in another, somebody else's phone)? Check the headset connector/pins that they're not broken.
In the worst case, the phone could be broken, if it no longer accepts the headset. Do you have some other Pop-Port headset that you can try?
Cheers. I just tried the headset in another phone and it doesnt work. one of the pins looks shorter than the others so its back to the shop i reckon!!!
thanks for your help
Gday all
I got a new headset yday and plugged into the phone, and worked sweet. then charged up the phone, and way hay it didnt work again. must be a problem with the phone itself or any ideas??
