Hello, I'm Pietro from Italy
I have just bought a nokia 6630.
I have a problem with this fantastic nokia: nokia pc suite don' t work with windows millenium .
What can i do?
I would only sync address list (with outlook) and tranfer files from cell to pc .....
WHat can i do?
Thx for all
You can upgrade to Windows 2000 or Windows XP, because those are the only versions of Windows that the Nokia PC Suite software for the 6630 supports/works on.
Otherwise, look for a network-based SyncML synch service such as http://www.mightyphone.com/ or use apps such as "SmartVCard" to export/import contacts on the phone to/from a file, and then import/export them to/from Outlook.
