Hy !
Can "logs" on 6600 show the date and time of the calls? If not, is there an app which can show both outgoing and incoming calls and the date of hte call? I got Extended Log, but it only shows outgoing comms and the built in logs are not giving any date and time reference.
Thx!
Open the built in log application, press the right button, you will see the general log.
The general log has the date and time with each entry.
rohitkhannak wrote:Open the built in log application, press the right button, you will see the general log.
That's the problem: in general log I got only the call duration, but no time and date... I don't know what happened...
Thanx
Date & time is in the header bar (with the left & right arrows next to it)
In logs, under general, I got the following direction (in / out), type, duration and number. No sign of time / date of call. I don't know if it's something that depends on me...
I don't know what is happening to your phone but my call duration is shown in a separate part of the log, but the time of the call and date is listed in the outgoing, incoming and missed sections of the menu. It sounds like you have a third party application already installed.
