Bluetooth wifi simultaneously
3 replies · 2,026 views · Started 02 February 2005
It seems that if Blue-tooth is activated, it does not allow Wi-fi to work properly. If I change Wi-Fi setting Allow Blue Tooth to false then Wi-Fi starts to work again. Is there a conflict between the two?
wadood wrote:It seems that if Blue-tooth is activated, it does not allow Wi-fi to work properly. If I change Wi-Fi setting Allow Blue Tooth to false then Wi-Fi starts to work again. Is there a conflict between the two?
I have both enabled and the wi-fi works fine
I have the same problem. That's why I have BT turned off unless I really need it
Yea I think there is a small confliction between WiFi and Bluetooth. Even if it work well, it reduces the signal a bit.
