[Help] *#7780#, *#7370# and [green]+[def3]+[*+] Reset Codes
6 replies · 31,714 views · Started 02 February 2005
My Nokia 6260's microphone has not working for around 2 weeks already. And I thought it was a network problem that people cannot hear what I say (but I can hear them)! Heck, I can't even do voice recording (using the built-in voice recorder), so confirmed it's the microphone problem. Damn lousy phone... Anyone experience this issue? My phone is only 1 month+ old 😞
Will resetting it to factory defaults solve the microphone issue? I came across *#7780#, *#7370# and [green]+[def3]+[*+] codes. Questions, what are the differences between these three codes? Will it wipe out everything or just settings? Any precautions that I should be aware of and also side-effects?
back everything up then try the call button+3+* trick, it will wipe out everything and it wiill become like it was from the factory and then see if it works. if it doesnt then your phone is under warranty anyway and youll get it fixed/ replaced for free.
DaViD_BRaNDoN wrote:Thanks for the info but I'd tried the *#7370# reset code
778 wil restore your ini files and preserv user data...
737 will erease all of data from phone memory and than restore new ones from ROM, u will loose all of your personal data, such a Contacts, messages, images, etc...
Three key boot up trick is the same as 737 but they dont ask for sec code and they can be used even when the phone wont bootup
Cheers,
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]
Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
how does that work exactly.. cuz i tried it.. and when the phone boots.. its still locked.. no change.. no reset.. 😞
