I use a Nokia 6600 with tmobile and since the last upgrade of the Agile Messenger, is seems to no longer work with MSN even though that is still one of the options to use on it. i KNOW im using the correct login and password so what has changed to make this work again?
Agile Messenger, does it work with MSN anymore?
Same thing here since the upgrade. cant log in😞
I have N-Gage, I was SOMETIMES having the login problems for a few days and 3 days before it said new version available...
I downloaded it.
Now it works perfectly.
