Is it possible to send audio/midi tones using multimedia or bluetooth, as ive tried both ways and not had them work.
Also can any provide instructions on how to have your phone connected to your pc using blutooth, eg -does service pack 2 need to be installed or is there any other way etc...
Thanks... 😊
Multimedia/Bluetooth
madmark wrote:Is it possible to send audio/midi tones using multimedia or bluetooth, as ive tried both ways and not had them work.
Thanks... 😊
Nokia PC suite.
well,i think better if you use the software provided by your bluetooth adapter manufacturer. Don't use windows software as it will conflict with your adapter.
i am using windcomm and it works really well, 😊
