i install an apps which doesn't seem to work on my 6620. Its a program call irremote and now i can't uninstall the apps. I tried to delete it using the nokia pc suite install application software but the apps didn't show up. Anybody know?
HELP uninstalling apps on 6620
einstoned wrote:i install an apps which doesn't seem to work on my 6620. Its a program call irremote and now i can't uninstall the apps. I tried to delete it using the nokia pc suite install application software but the apps didn't show up. Anybody know?
First run app. manager (official) on your phone and try to remove application, if trhat dont work, run some 3rd paty file manger like seleq or fexplorer, go to E or C (where u install application) sytem/apps/ search trough to find out application and delate whole folder.
restart phone, run app manger (symbianware) and clean up if some file still exist.
Thats all Im in hurry so :con?
If u need aditional help feel free to find me on
http://www.symbian-freak.com/ u can reach me trough forum, shootbox or Ask guru form
Get more guides and advice at:
I couldn't get irremote to work either. I emailed them and they said that they would have an updated version for the 6620 at the end on Jan. I didn't have any trouble uninstalling it.
