How to install a .SIS application via card reader ???
5 replies · 4,192 views · Started 03 February 2005
If u got no datacable, copy ur sis file to ur memory card & put in a folder(anyname)
From the phone, use FExplorer get to the folder with ur sis file & open it. This will begin the installation process.
first, install a file manager like FExplorer or seleq or whatever, then copy the .sis file in the root folder of ur mmc. start the phone, start the file manager, click on the .sis file and tadaaa
After installing .sis file, where can I find the *.app files of that .sis file? I always install application to MMC.
Is there a folder in MMC similar to "c:\program files" in windows?
Regards
Emre
E:\system\Apps\ is the directory (or folder, if you prefer), where apps installed on the memory card are put.
C:\System\Apps\ for those installed in phone memory.
