hi...
i have a 7 MB AVI file
just wanted to know
if it was converted whats its size will be ?
question...
In any case less then 1 mb. With max quality you'll probably still keep it under 1 mb. All depends on how long the vid is.
Its 3 mins and 55 sec
Check out a old page of mine: http://nokia.warlocks.be/NokiaNimSettings.htm
That would give you a good idea. 7 is normal quality, but I use 4 thats way better. (quality can only be chosen in Multi Media Pro convertor from forum.nokia.com)
The links to the vids don't work anymore because I needed the webspace.
I wonder if I can talk to you in MSN or something
so you could help me
My msn: [email protected]
But I won't be online that much because I've got this week off.
