Problems with Memory Card
1 replies · 2,627 views · Started 03 February 2005
Hello can anyone help me.
I've recently had my 6600 reflashed, because of lock code problems but now my memory card won't work. All the icons are there but theres nothing in the app. manager and I can't get any memory details. I've phoned Orange and they told me that the software upgrade I had done has made all my games incompatable and I would have to bye them again.
I haven't got a card reader to check my card, and it doesn't seem worth it as I am getting rid of the phone at the end of the month.
Can anyone make any suggestion as Orange were next to useless.
Thanks Janine
try the steps below
1.download & install file explorer (FExplorer) or use your card reader
2.go into e:system/apps and into any folder that appears
are there any files in these folders.if there are then maybe the firmware aint happy with the mmc part of your phone.
try going back to the old firmware or copy everything to your pc through the card reader and format the mmc on the phone (with the new firmware) then copy everything back.
this might solve it
