how can i delete app from my 3650?
i down loaded an app but it didn't work so i can get into it. and now i want to delete it i press the clear button it says unable to delete folder item.
any ideas?
any ideas?
urban wrote:how can i delete app from my 3650?
i down loaded an app but it didn't work so i can get into it. and now i want to delete it i press the clear button it says unable to delete folder item.any ideas?
Kamalayan wrote:Go to Tools-Manager then locate the program then uninstall if its a JAR file go to Apps-Options-remove. 😉
Install (in Nokia): AppMan v1.04 (just if you dont now where is the folder where the program is intalled!)
Install (in PC): PC File Manager for Nokia
Use AppMan, and discover where is the FOLDER is install the program what you wont to remove, go to PC FILE MANAGER and find the Folder that the program is install!
After you find but click and press DELET!
I remove one program in that way, you undestand me?
You can download in EMULE or send me your mail and I send everything that you wont and I help you!
