Hey Guys,
I am using Nokia 7610 and this newyear eve some1 send me a msg thru blutooth,which was Caribe Virus and I installed it by mistake.This virus has infected my phone very badely.My battery dies very quickly all my application work very very slow.Any1 knows da solution plz mail me @ [email][email protected][/email].
Thank u
How 2 remove Caribe Virus from Nokia7610
Read my thread there is the information on what to do.
A good way to see if Caribe is running is to hold the menu button. It will tell you which applications are running.
Hope it helps.
/Khristos
/Khristos[/QUOTE]
Hey,
Thanks 4 ur reply.My Caribe application is running 24/7.sometimes I get a msg saying carribe application closed,but then again it cummes up.Where can I find ur thread info.I am new here
search on the forum on how to fix carib and u will find a file which u should install and caribe will be removed
Install this application it's from f-secure antivirus solution's hope it remove's the virus .
Khristos wrote:Read my thread there is the information on what to do.A good way to see if Caribe is running is to hold the menu button. It will tell you which applications are running.
Hope it helps.
/Khristos
jazzy1 wrote:Install this application it's from f-secure antivirus solution's hope it remove's the virus .
oh thanks dear you save me the file f-cabir.sis is good and the worm is disipear and my n-cage work very good. thanks so much this is my email [email][email protected][/email]
thks alot.me too have removed the caribe virus... :icon14: :tongue:
thank you soooo much for this! been pestering me for months :redface:
cheers - PM
