Register Code for Mobile VR Pool on N7650 ??
8 replies · 3,080 views · Started 23 October 2002
hello, someone know a register code for this good pool game on MGS ??
thx
Yes the company that make it will know the Register Code and will tell you it if you hand over some cash! :x
No Warez on this site, please go somewhere else
FYI, you won't be able to warez this or most other games as the code is based on the IMEI of your phone, therefore each code is different and only one will work for your phone. :P
TO say that is naive J2theizzo, large software houses that produce software that costs upwards of �1000 spend a lot of time on making uncrackable serial codes etc, yet they still get cracked.
Take WinXP for example, the reg codes are based on the serialnumbers of the hardware in your system, yet over half of my friends are using cracked copies of XPpro on their home machines!
Its only a matter of time until someone with the requisite skills to reverse engineer the symbian software finds out how it calculates the codes and makes a key generator which you just type in your IMEI number and it gives you a code.
The only reason it hasn't happened already is because there is no demand for it in the warez circles yet.
True, but the majority of Symbian and Series 60 developers just don't bother to secure their software with IMEI! Believe me there are noumerous of warez for the 7650 floating arount! Companies have to keep up becasue there will be no company that will make software soon! :-?
<Marge SImpson type Hmmmmmmmmm>
Warned you I did, but nobody listen to poor old Zathrus.
[quote="headshox"]TO say that is naive J2theizzo, large software houses that produce software that costs upwards of �1000 spend a lot of time on making uncrackable serial codes etc, yet they still get cracked.
The only reason it hasn't happened already is because there is no demand for it in the warez circles yet.[/quote]
Guest's come on here just about everyday asking for warez, I realise that there is always a way around something, no matter how much a software company try's to protect their software there will always someone out there to crack it.
But does that make it right?
If warez is so easy to get hold of, people will get it. But what kind of affect do you think this will have on the small software companys?
To assume there are no warez for er6 and er7 machines is misguided... does anyone remember a little program called Regit for the er5 machines?? In the last release of this app it would register upwards of 350 psion apps right there on your psion and new rips still pop up from time to time... It wont be long before something similar appears for the current batch of hardware. Suck on that one lol 😃
Of course enough cracked versions available of symbian apps.
You can't protect a app, if they really want it, then it's just a mather of time before they get it.
The IMEI is a good start, most users will pay.
[quote="bollox"]To assume there are no warez for er6 and er7 machines is misguided... does anyone remember a little program called Regit for the er5 machines?? In the last release of this app it would register upwards of 350 psion apps right there on your psion and new rips still pop up from time to time... It wont be long before something similar appears for the current batch of hardware. Suck on that one lol 😃[/quote]
As I've said, I know there's warez
:evil: Just as long as it stays off the forum :evil:
