I possibly need to Hard Reset my Nok3650, and do it all the way again. So, i need to know...
-How do i maintain Contacts, ToDo's, DateBook events and notes ? I can't use the Backup function from the Backup application, as it will remember all the state of the phone, and i need just that information ?
-What about the settings from the Settings tab ( e.g. internet settings and so on ) ?
Thank you in advance!
Menu->Extras->Memory->Backup phone mem.
thats what you need to do to backup contacts, bookmarks etc.
Whats the backup application that'll remember the state of the phone?
Otherwise you can synchronise contacts and calender with Outlook on computer, transfer notes/images etc to computer and after resetting transfer it back to phone.
They are some errors in the memory ( e.g. applications already deleted and invisible loading and so on ), so i wont keep the state of the memory. I just want to keep the information as contacts, todos and calendar entrys. So, the backup system won't help.
The second way seems to be the right one, but i don't have the Nokia data kable/suite. Is it some program, which is able to save all that data to do MMC, so i can transfer the files using a standart Card reader?
Use a backup utility for contacts use contacts manager, for backup in drive c of ur phone use sprite backup!
masterforce wrote:They are some errors in the memory ( e.g. applications already deleted and invisible loading and so on ), so i wont keep the state of the memory. I just want to keep the information as contacts, todos and calendar entrys. So, the backup system won't help.
All u need is:
sVcard for contacts
sVcal for calendar
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
Thank you very much!
What about something for Memos?
masterforce wrote:Thank you very much!
Memos!?
Memos is also in calendar, or u think about notes (notepad)
If yes, i have solution 4 easy manual backup, for more information u know on which addres u can reach me... 🙄
Cheers
