Hi there,
I just got a 7650 and I am having a large amount of pain getting it working with PC suite. It seems that a few people are having trouble but I though it would have been easy?
I have an XP sp2 machine that is about 2 months old. I just bought a bluetooth usb thingy and everything is pretty up to date on the machine.
I whacked in my Bluetooth dongle and it started communicating with my phone. I then installed the drivers that came with the dongle and now there are two blutooth apps running in the taskbar. The standard windows one seems to recognise the phone but the new one says the device is not recognised??
PC suite also acts pretty weirdly, Sometimes the splash screen will come up and the nothing happens, sometimes it says to connect the phone (which already seems to be connected) and sometimes it says to put a unique name but nothing i write in is acceptable. Also, the only way to uninstall it is to remove all nokia bits fronm the reg.
And the nokia connect icon in the systray never finds anything!
It seems so messed up, but I tried installing it on another machine and it still didn't work?
Is there someone out there who can help out the brotherman here???
Sfinkt wrote:Hi there, I just got a 7650 and I am having a large amount of pain getting it working with PC suite. It seems that a few people are having trouble but I though it would have been easy?
There is some problems with BT on SP2 mashine, did u tray to download and update BT dongle drivers!?
Did u tray to pair phone with PC!?
Did u try direct serial conection!? (Right click on BT icon in try, Quick connect, Blouetooth serial port, your phone name...)
Hope this help
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
