Nokia 9300 and Mac
4 replies · 3,068 views · Started 06 February 2005
Jannis, although I'm using Jaguar, I am pretty confident that you can't use any of Nokia supplied software with our Macs - that's because they all run under Windows only! I've not tried doing most of the stuff that I did with my 9210i and my mac with the 9300 yet such as reading my word docs and pdf files created with the mac but I think they should work fine. I've used bluetooth with 10.2 and my 9300 to send files and that's no problem. Haven't tried iSync yet though. Even in this state of affair, I think two slick pieces of hardware like a 9300 and PowerBook just look great together!
Hi Jannis,
I also use a Powerbook together with the 9300. Until now there is no Isync support for the 9300. Documents and Programs are no problem to transfer to the 9300. Currently I use my old 6600 together with isync and then export all dates via Bluetooth from the 6600 to the 9300.
Bernard
thedoe!! wrote:Hi Jannis,
Bernard
