Gprs
7 replies · 1,451 views · Started 06 February 2005
Hello i am having some problems setting up my grps/wap!
i have tried the settings from the sendo website but everytime i try to connect i says
'internet unable to connect, check connections settings'
whats all this about?
ne help wud be appreciated
jason
Can you give us some more information...
What networrk?
What country?
Which firmware version?
Is this just Opera, or is WAP doing the same?
Ok i am on vodafone, im in the united kingdom, i have the latest firmware version from the sendo website, and i dont have opera on my phone its just on the wap.
do i opera on my phone for the wap to work?
thanks for ur speedy responses
well i can safely say vodafone are shit! just phoned them and asked them about the settings for my gprs ! they sed
sorry we dont yet have the settings for the sendo x but we can forward your call to sendo! so they did that and it was all automated cos its bloody sunday!
what a bunch a tossers they all r at vodafone!
so if you lot can help with my settings which no doubt you can it would be much appreciated!
thanks in advance
jason
jskaife wrote:well i can safely say vodafone are shit! just phoned them and asked them about the settings for my gprs ! they sed
thanks in advance
jason
Phone them and say you have a Nokia 3650. This has the same OS as the Sendo and so the process is the same.
Your an amazing person u know that!
went onto there website instead! went to configure my phone blah blah! selected the nokia like u sed! they sent me the settings! capish! it works!
nice one mate! i owe ya one
Poor old Vodafone - they do come in for some stick! I made two calls to them regarding UK Vodafone Pay as You Talk GPRS on my Expansys Sendo X. The first time the guy I spoke to sent me a configuration text message (which I think is the same one you can get from the Sendo website) but he also enabled GPRS on the account which is not set up by default - crucially this takes 48 hours (actual) to come into effect.
The second call was last night (about 9:15 pm if the guy works regular shifts!) as I'd successfully got the browser working and managed to retreive emails from a demon pop account however I couldn't get outgoing emails to work. Turns out you have to set up a new connection with diferent settings to get this to work. For the record you need to copy the default connection settings and change the following:
username: web
password: web
homepage: none (clear all contents)
You then need to use this new connection as the default connection in messaging. As posted elsewhere in this forum the smtp server address is send.vodafone.net.
It works.
Both times I called Vodafone I explained that the front end of the vodafone firmware is diferent from the expansys one and I think if you can overcome their initial resistance to departing from their script and get them to jump ahead through their written instructions so you end up in the screen where settings actually need to be changed they can be quite helpful - kinda helps if you know what is where in the OS first though.
