New RS MMC from ATP is not compatible with the 6630!!!
7 replies · 2,583 views · Started 06 February 2005
I've just been checking out the specs on the new ATP 512MB RS MMC http://flash.atpinc.com/product/rsmmc.php
They say it's dual voltage, but if you check the specs it says it runs between 2.7 - 3.6 V and NOT 1.8 Volts!!!
Bloody hell, I'm really beginning to lose my patience with these companies, especially Nokia for the lack of support for the 6630. 😡 😡 😡
I dont see Dual Voltage mentioned anywhere on that page?
Depends in on what reader you have it will fluctuate between 2.7-3.3v... in dual votage cards this is the upper voltage band (3v) hence these cards are NOT dual Voltage.
It doesent say they are Dual Voltage or MobileMMc complient and you will need cards that specifically say they are RS DV MMC or MobileMMC. Were not going to see 512 till summer at least.
parks68 wrote:I've just been checking out the specs on the new ATP 512MB RS MMC http://flash.atpinc.com/product/rsmmc.php
it is your fault for reading things differently and failed to comprehend
faizalmzain wrote:it is your fault for reading things differently and failed to comprehend
Yes, the spec you were reading was from our regular line of RS-MMC. The new DV-RSMMC can take a voltage range of 1.7V-3.6V. Email me at [email][email protected][/email] if you have any more questions.
-Jeff
ceanth wrote:just what i was thinking
Hey guys,
Perhaps in a little after these cards get out we can run a special for your club! Stay tuned, you should all be seeing these cards appearing very soon everywhere.
-Jeff
jhsieh wrote:Hey guys,
-Jeff
Nice one 😉
