Apps for 6260
11 replies · 6,011 views · Started 07 February 2005
well,actually A LOT. so it depends on you. Give it a try and you will know which one suit you, 😊
hey, im having the same problem as you- if anyone can send some or give sum useful sites id be grateful too!
w036530655 wrote:hey, im having the same problem as you- if anyone can send some or give sum useful sites id be grateful too!
Since this is a series 60 phone, almost all programs available for this type can be used and installed. however, camera related softwares are not that reliable on this phone.
Ex:
PhotoBase software's other features can be perfectly used but not the camera function, same as PhotoRite SP. Though in photorite sp you can use the camera but you need to exit the built in camera of 6260.
3D Pet fish work flawlessly
eXPlode arena
smart movie
CameraFx- can work but need to exit the builtin camera software when in play mode
I think there is no dedicated camera software yet for 6260. If you know something, please feel the freedom of posting it here. 😃
theres hundreds of programs available, depends what you want to do?
you can control a TV, you can contol winamp on ur pc, you can play a hell of a lot of games, you can have loads on camera type programs, goes on forever
i wanted to see what kind of apps are available. i have plenty of games, especially witht eh gameboy emulator. i had a number of camera apps but dont need that anoymore since the 6260 isn't limited on video recording. anyone with links to lists of apps would be helpful. thnx
Why dont we just put a list here? The Must have apps in S60... It should help everybody
I'll start with the all-mighty free one!
1. FExplorer - Works like a Windows Explorer in S60 (free)
2. ...
There's a lot of camera apps for 6260. Here are the ones that I've tried and works perfectly....
Camera Magica
PhotoAcute
CameraX Pro
PhotoRite SP (if you want to do effects)
and for Video ... a good one is Camcorder Pro, can record in QCIF (176x144) you can also change the frame rate up to 15fps.
lol, i'm quite interested in series 60 softwares and i have a list of my favourite apps.
Total IR-Remote control
SVcard-BAckup your contacts now with it
Resco Viewer-Best to view your images
Calcium-Easy and exquisite calculator
File Manager-Easy to use
Sele Q-Same as file manager but it can take screenshot in a good quality
Message Saver-Feel free to save your messages into .txt files now
Explode Arena-U'll get addicted especially when u play multiplayer via bluetooth
Killer Virus-A shooting game using camera to kill virus
Mosaquitos-Almost the same as killer virus but it is more exciting
Fifa 2004-quite ok
Chinese Start-Chinese star for symbian
Turbo MSN-msn messenger for symbian
MP3 GO-MP3 player with playlist
Ultra MP3-MP3 Player
Smart movie-View your movie in full screen and quite good quality
Switcher-Task manager for Symbian
Quick office-Word, power point and excel for symbian
krycek wrote:There's a lot of camera apps for 6260. Here are the ones that I've tried and works perfectly....
Camera Magica
PhotoAcute
CameraX Pro
unfortunatelly i can not make the photoacute work for my 6260. Tried all of them even the v2 but nothing do you know why?
thanks
