It's MY LUCK AGAIN - 6630 - wierdest problem - please read! ( Unable To Access MMC )
7 replies · 3,763 views · Started 07 February 2005
Hi there!
My firmare is 2.39.15 ( 11-11-04 ).
I have pressed ON button, and selected PHONE LOCK and entered: 12345 for password.
Phone LOCKED ALLRIGHT!
screen lights up only when i pres ON button, nothing else. buttons not responding.
i don't see unlock button
when i simulate a missed call, and hang up, phone show 1 MISSED CALL and i see UNLOCK on left side key.
but when i press it, it disaperes..
theme is something like locked, cuz it still shows remains of sound control during call if u use loudspeaker.
Please, do u know how to reset phone or to turn this STUFF off?
I have one more problem, to quote myself from other thread
Only problem I have is this: my phone from time to time ( 5 times in 6 hour use ) trows this msg: Unable To Access Memory Card when i try to take pics, or to browse the MMC.
Only fix is to restart it, or to open MMC doors, and just close it.
Is anyone able to help?
i think it's software isue, cuz..u don't touch anything, u just restart, and it's okey, couldn't b hardware..
Thank you all!
I hope u can help!
I had the same problem with the MMC but i found it was when an application was open in the background and using the mmcard.
but i am on version 3.45.110 02-12-04
not much help.......
what do u mean by "when apps are open in the background"?
does it mean, that i have to close ALWAYS EVERYTHING in order to access MMC?
that's stupid
today..i think i'm gonna get a replacement
what do u think?
has it reseted on you ( atleast once? )
tnx
2PACroatia wrote:Hi there!
Thank you all!
I hope u can help!
I have got the same firmware as yours .. and my phone works perfectly ...
I don't understand very well what is happening to you ... When you press on the Unlock key, don't you get any message : "Now press *" or a window asking your unlocking code ?
For your second request, if I am viewing a picture from the MMC card through the Gallery, I can in the same time take a pic with the camera .... without closing the gallery application before.
Are you sure your MMC card is perfectly set inside the phone. Or try to reformat the card (after backup ... 😉 )
i've changes my 6630 for new one ( only device, not MMC )
i can't wait to see results
btw. 1st charge: 12h
2nd charge: 12h
3rd charde: 2.5h
is this okey?
i have the same firmware & have not had any problems like that either, those charging times should be fine with yr new phone 😃 it might be a good idea to format yr memory card before you use it with yr new 6630.
hope this one works ok this time 😃
i hope 2
4 now, i haven't had any problems
few more questions: is it possible to delete preinstalled themes? my phone is TIM ( italian version ) so i have TIM theme and Nokia theme
is it possible to delete any of these?
is TIM theme fastes because it is preinstalled?
do themes slow down the cell? theme like firefox?
when u have a pic on MMC, and u set it for backgorund, and later, you delete pic from MCC, phone didn't copied the picture to its memmory, so the picture is totally deleted, right?
when u install an application, and leter on your phone u go REMOVE, is totally removed?
is phone in state just like before installation or it's like in windows, when u uninstall u have some files still left, and only way to get clean comp after few monthes it's format
thank you for all the help
p.s. My MMC doesn't have any NOKIA logo on it? is it orginal?
and u think i should format it anyway ( now it's working fine )?
p.s.
this is probobly the best support forum for nokia 6630
i have recieved answeres in shortest time period
guys, keep up the good work..and try to answer few more questions 4 me..
this is my first symbian phone so, don't be mad if the q's is silly
peace
