Does anyone know how to set up VPN on 6630??
Do i need a nokia firewall or can i use my existing one??
Cheers
Pete
Cheers
Pete
Step 1 thats the farest step I reach. I have really no idea how this should work.
After entering IP I tried so sync... untill step 1 everything is ok but it will not go one :frown:
I tried with the IP of the company I work for. Even the admin had no idea how to continue.
But I cant believe that you need a nokia firewall to connect with VPN...
You don't need a Nokia firewall, but you need a Nokia policy server to configure the VPN client software. The catch is that you get the policy server with the Nokia firewall. Until an alternative way to configure the VPN client is provided by Nokia, there is no way around this fact, I'm afraid.
