hi all ,
i have Eti camcorder on my 6600 , i dont know which version , but when i make a movie and send it to my computer over a Usb bluetooth device , it doesnt play the movie and says : Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file , thats when i use windows media player and the same is by Real player
so please some one help
what type of file does eti save the video as?
i know that realone can play .3gp and .mp4 files but requires an extra codec which is available for download. Also make sure that you put the file extension at the end of the filename if you've renamed the files.
my Eti saves . Eye and .Ear files
you need a converter - do a search on this forum, there is a very long thread about it.
i found 1 software EYECON , but i tried and tried and it doesnt work !!
you should try to find on the net some codecs
i doubt theres any pc codecs for ear or eye files
uzi2 wrote:hi all ,
i have Eti camcorder on my 6600 , i dont know which version , but when i make a movie and send it to my computer over a Usb bluetooth device , it doesnt play the movie and says : Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file , thats when i use windows media player and the same is by Real player so please some one help
hi u try to install NOKIA Multi media player and try to play the file.., by the way from where u got Eti camcorder..i am also looking for that
sreejith wrote:hi u try to install NOKIA Multi media player and try to play the file.., by the way from where u got Eti camcorder..i am also looking for that
Nokia multimedia player doesnt play those files
maybe in time the people who made eti will make a player for the pc or a codec will be made for it.keep checking the website.
It works fine and my computer plays them, but I think it uses quicktime player. Email me if you need help [email][email protected][/email]
