Is There AnyWay To Make Lock Kepad Autolock Without Seleq???
13 replies · 4,483 views · Started 23 October 2002
i think, i dont know where dis is true, i explorer my back up files (when you back up using data suite for 7650) i go to some folder i found the system/shareddata you can see there is all *.ini in der, one of this file (you can view it on notepad) you can see "autolock = 0" i think 0 means off and 1 means on, i dont know if this is true, but when i tried to change it on my phone (copy the file that i change on my pc) the destination is in use, if this is the case, could some program can change an *.ini directly???
I can see that a good idea .... There are two files 1 is in C: and the other is in Z: ... The one in C:\system\shareddata\100058EC.ini can be edited because it is in the C: .... possible threat ... but I'm afraid to ruin any setup of my phone ... maybe our seniors like Dazzler,EwanFrepoc, J2theIzzo or others can try and findout 😃 😃
Ok! I Found It MySelf When I Thought About It
Now I Have Bigger Problem My Seleq And E-FileManager Or Other File Manager Program Stopped Working Because I Have "Played" With The Date On My Phone And I Dont Want To Use Restore Option In The Nokia 7650 Pc Suite!
How Can I Copy That File In To C:\system\shareddata
Anyone Has Any Ideas!!!!!?????? :-?
Even though I am not a senior 😊 i can asure you (and yes I have tried) that you cannot delete,rename or overwrite the file mentioned above on the phone! It is a configuration file and cannot be changed either on C: or Z: The Autolock does not refer to the Keypad lock but to the Security Lock (then one where you need the lock code to unlock)! Sorry! :-?
[quote="mjsee"]so how the program of seleq works if it doesnt work that way[/quote]]
maybe seleq detects if the "Lock Keypad" window pop up then the "Yes" = to true
this is just my thought
cos u still can see the "Lock Keypad" window pop up first then its locks the keypad so seleq not disable the "Lock Keypad" features. They just automaticlly press the "Yes" button
[quote="Pichu"][quote="mjsee"]so how the program of seleq works if it doesnt work that way[/quote]]
cos u still can see the "Lock Keypad" window pop up first then its locks the keypad so seleq not disable the "Lock Keypad" features. They just automaticlly press the "Yes" button[/quote]
I agree on what you've said.
Yep a simple program would surely do it.
Im willing to bet it would not be that hard to make either, but becons the question of why no one else has made it yet.
You wonder, I deliver 😃
Please visit :
http://www.allabouter6.com/phpBB2/viewtopic.php?t=3576
Your request come true I hope 😃
