Nokia 7710 Blank Screen unable to Start
14 replies · 8,246 views · Started 09 February 2005
Just installed some programs in the Nokia 7710 and it Hangs.... Took Out the Battery and now only Blank Screen. Any one knows the resetting button? Holiday in my country now. I will appreciate if any one can HELP. The Nokia 7710 HAVE NO NUMERIC BUTTON.
Yes it have i have made a thread i.e Full Formatting Tips Your can get throw it and Format your Phone.
The phone is not getting started so where to press *#7370#.
jazzy1 wrote:Why u go for complicated way go for hassle free way try this code only *#7370# !
How to press Numeric Nokia 7710 have no keys...
edmondtay wrote:How to press Numeric Nokia 7710 have no keys...
Just tap the code *#7370# on "on screen dialler" that's all.
Attachments: ScreenShot004.jpg
Was this ever resolved ? I'm having the same issue.
"jah - Vicky's solution does not require the use of the dialer! "
But it does require it to start 😉
Mine does not start up all - just the backlight when the charger is in and nothing without it.
Mike
Can u able to see black screen when u do the above things
read carefully and then do one by one.
Vicky wrote:Can u able to see black screen when u do the above things
When I try and start the phone with the battery, the screen flickers once real fast and is then black as in not on. Holding down the buttons does nothing.
Plemix, where I bought the phone, is sending me a new battery as they believe this may be the cause.
So the question is, can you not start the phone with just the adaptor?
Because currently, when I plug in the adaptor the backlight comes on and thats about it.
Mike
or you might try charging the battery on another phone. If battery is at 0 charge, phone will not start. It needs some juice in the battery. Did you try leaving the phone on the charger for sometime?
-a
akmits wrote:or you might try charging the battery on another phone. If battery is at 0 charge, phone will not start. It needs some juice in the battery. Did you try leaving the phone on the charger for sometime?
-a
Yea, I left the charger in for a couple of hours. The whole time is was in the backlight stayed on and that was about it. I'm thinking the power connector is bad.
Mike
Hi I know that earlier releases had problems with browsing and crashing, go to your local support centre for free software upgrade. Also check out www.nokia7710.com they have a support centre.
