Can u use a ringtone from your card?
6 replies · 1,975 views · Started 10 February 2005
[FONT=Arial]Hi
Is there anyway to choose ringers from your card instead of from the phone itself? (This way I can use a lot of .wavs) thanks 😊
[/FONT]
mythloaf wrote:Put your wav files to ur cards E:\sounds\digital
yeah but then when i am in "profiles" customize - select ringtone, it doesnt pick up any from the card - how do I point it there?
Razzie33 wrote:yeah but then when i am in "profiles" customize - select ringtone, it doesnt pick up any from the card - how do I point it there?
Whats your fone model?
Razzie33 wrote:3650
Be sure it is in your e: wich is your mem card and inside of it is Sounds\Digital
E:\Sounds\Digital coz i put all of my midis and wav files in that directory and works just fine double check dude!
hmmm
in my e i dont have a sounds/digital folder ..................... ill make one and see what happens -
**** k i made a sounds folder (couldn't make one insode it for "digital"😉 but it works!!!!!!!!!!!!!!
swwwwweeeeeeeeeeeeeeeeeeeeett
thanks a bunch mythloaf
