New owner = many question
2 replies · 2,175 views · Started 11 February 2005
Hello All,
I'm a happy owner of a Sendo X+ 1SD (..after the firmware upgrade,:->😉.
I just have some basic question for you all:
1)Which aplication can i close in order to play ngage games (ex: tw2004 or motogp).
2) Does some one have the irda psilock working with sendox?
3) how can i costumize the ring tone for a contact.
4) i just istalled netmonitor from nokia(not comatible), how can i erase the klink created in the MENU , same happend to video MMS from vodafone.
5)i Notice after installantion(mainly in the SD) of some sw to the SendoX that some time i have some miss call or memory full (when i do a sw reset after some installation everythinh works just fine) anybody notice this
6) which aplication are consired a MUST HAVE?
Sorry for so many question.
Regards from sunny Portugal,
Bruno Fialho
1. No-one is likely to answer this on this forum as copying and using n-gage games is illegal
2. Never tried it
3. select the appropriate contact then OPTIONS/RINGING TONE and select the desired tone
4. dunno
5. sounds like you have corrupt or incompatible 3rd party software, test them one by one or see the other forums for apps that work
6. Bounce & a file manager
The answer to question 4 is if you go to tools and then program manager everything u install is in there. Find the program u want then remove it ! this shud remove the program u require deleting!
