PC/N-Gage pic transfer
3 replies · 1,914 views · Started 11 February 2005
Hi Guys,
Hoping someone can help. I am trying to get a picture from my pc to N-Gage (want to use it as wallpaper) but I am totally stuck on how or even if I can do it.
Someone mentioned bluetooth/wireless connect - do I need this coz I don't have it!
I installed the phone software onto my comp then attached phone via usb port.
I open programme and it tells me to attach phone, it already is attached and if I click ok, the please attach phone stays there and I have to just cancel.
My phone doesn't have a memory card or anything, it's just the phone with the internal memory (if that's what u call it) and I cannot figure this out for the life of me so if anyone can help I would really appreciate it.
Julia
something in the pc system tray called mRouter should appear, click on this and a window should appear. this lets you select the method(s) you want to use to connect ur phone to pc, you can choose irDA, which ngage doesnt even have, serial cable, usb cable or bluetooth.
select usb and close the window, the pc suite should register the device.
The USB cable connection with the N-Gage goes directly to the memory card. If there is no memory card, it won't do anything.
The PC Suite program, on the other hand, does not work with the cable, but only if the PC has Bluetooth.
If you don't have a memory card for the N-Gage, or Bluetooth for the PC, and do not intend to get either, one option is to send the picture as an email attachment to an account you have configured the phone to access.
N/A wrote:The USB cable connection with the N-Gage goes directly to the memory card. If there is no memory card, it won't do anything.
Thanks - I am definitely planning on buying a memory card next week!
