Hi All
i've got a stupid question for you.....
but i've not found a answear.
can i upload a jar file or a jam file to nokia 7650?
What is the diference jar and jam file?
If these file are not for nokia 7650.. which phone can load them?
i've found many jar/jam file in www.midlet.org but i don't know wich phone can load them...
thank for reply
Regards
conte renier from italy
I have tried the .jar or .jad I think.
they can be uploaded like that and will install.
The 7650 does not need the jad file just the jar 😃
Not heard of jam files before - the app that runs the programs is known as the JAM (Java Application Manager)
jar files are only another name for a ZIP file, so if winzip will open these 'jam' files, just rename them to .jar and they should work
- if not, ignore them!
