Hi all
I have installed the Application HelloWorld in my 7650.....it has installed successfully in my phone..problem is I cannot find out where the Appplication went, it is not visible in the phone........so to find it out, I am trying to install the SeleQ software..............now, the problem is the software is not installing.....everyime I try to install the software through PC Suite and IrDA connection, the installling starts but the 7650 is disconnecting after some time.......I have tried 4-5 times..........what is the problem?
Nimo :cry:
It seem that the problem is not SeleQ. I think the problem is the communication between Noikia Suite and IrDa. Your Hello World may cause the error. I suggest you to refresh the Nokia7650 to original, then install SeleQ, Hello World'll be the last.
Hi..
How do I refesh the 7650 ? Can u tell me in a little detail ?
After refresh, what happens? I guess if I refresh, all the applications except the orginal ones from Nokia are deleted or what? and is it safe or might cause some damag to the phone?
Nimo,
I have encountered this problem after a new installation on my new PC - after contacting the support from Nokia, the last thing I have 'received' is to shutdown the phone, remove the battery ... and replace the battery ... and after that my connection was fine !!!!!!!! in fact you need to reset the irda port of the nokia.
Domi.
