Pc connect -file browser problems
6 replies · 2,291 views · Started 12 February 2005
Does this happen to anyone.
It is impossible to transfer/receive files since both of the buttons are over the files names.
this only happen with file browser.
Any ideas how to resolve this?
ps: my solution for now is copy directly to de SD
regards
BF
What operating system are you using ?
What version of PC Connect are you running ?
Choice wrote:Ok, the solution is change the font size in windows to Normal, instead big fonts.
Tks Choice, in changed the fonts to normal and now it works perfectly !!!
regards
