Corisoft have released SuperTree, a super list manager for the Nokia 9500 and 9300. The program is built around a database in a tree view form. There are plenty of customisation options (different field types, colours) and powerful import and export tools.
Author's Notes:
The List Manager for Professionals
SuperTree is a database organize around a treeview, create items and subitems. No limitation but memory to store your data. SuperTree allows a higly level of customization. Create your own fields from different kind of types. Set color for foreground or background or set font style for each item in list independently. Manage status of your items with check boxes. Import or Export to and from ansi text files. Customize your Import or Export methods with user defined templates. Manage more than one file at the same time, since SuperTree is file-based application.
Features:
* Define your own columns or fields
* Support for 5 field formats : Text, Integer, Float, Date and Yes/No flag
* Organize columns on the fly
* Adjust column sizes on the fly
* Select foreground and background colors for each item
* Select font style for each item
* Indent item the way you want
* Collapse and Expand items in the list
* Manage template for import and export to csv files
* Attach a note to each item in the list
* Show or Hide checked items in the list
* Autocheck items automatically when change the status of subitems
* Zoom in/out on display
* File-based application, open more than one file at once
