Hi, can anybody tell me how to transfer mp3 from pc to nokia 6600 without converting file format? Because this is what's gonna happen when I use PC Suite to send mp3 songs (mp3 converted in wav, I suppose)... I can only transfer file via IR, but they are stored onto phone memory as messages and not in the larger mmc... thanks 😉
How to transfer MP3 from PC to 6600
There are two ways to do this:
1) Card Reader
use the card reader to drag and drop the files onto your mmc and into the required folder.
2) 3rd Party FileManager, eg Seleq or
FExplorer (Freeware)
send the file to the phone using IR or Bluetooth not with PC Suite necessarily just use send to device then use the file explorer to move the file(s) into the required folder.
To do this in FExplorer (if you have the newest version) go to inbox find the file, and select cut, navigate to the folder you want, and select paste. easy eh 😉
The Card reader option is probably easier if you have one 😊 Good LOuck
