Can anyone help ?
I have an older 9210 and a newer 9210i. Both of them now have the same problem.
The front LCD has stopped working.
The internal LCD is fine.
The phone is fine.
The outside LEDS are fine.
The outside buttons are fine.
Is this problem easy to fix ? What tools do I need to dismantle the 92's ? I would prefer not to have to take them to Nokia.
Thank you,
Qsilver.
QS wrote:Can anyone help ?I have an older 9210 and a newer 9210i. Both of them now have the same problem.
The phone is fine.
Thank you,
Qsilver.
Doesn't any body have any help to render for me ?
If you need to dismantle the 9210 😊 www.aikon.ch...
TheSpecialBoy wrote:If you need to dismantle the 9210 😊 www.aikon.ch...
Is there anything in english ?
Thank you,
QS
I managed to do it myself. It turns out it was just a little ribbon connector come loose.
Qsilver.
