I can not reset my phone
6 replies · 3,326 views · Started 15 February 2005
I've changed my phone lock code, and I forgot it :redface:
now I want to reset my phone, I power off the phone, press and hold button Green, * and '3", power on but nothing happen.
I've already try soft reset but the phone ask me 'Lock code' :redface:
please help me!
tuanevnit wrote:I've changed my phone lock code, and I forgot it :redface:
please help me!
Try again that's trick work !
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
Do not let go the three keys until you see the "formatting" screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.
I do this trickmany time but nothing changed.
Someone said that this trick can-not change the lock code to default (12345)
Now I've just reload firmware with N-Box, lastest firm ware is 5.07 NHL-2NA.
when I press "*#0000#" the phone return:
V 5.07
30-07-03
NHL-2NA
I don't know why the date not changed :frown:
FunnyX wrote:try *#7370# 😊
That's not going to work coz it'll ask you for your LOCK CODE!
I've got the same problem, where the phone asks for the unlock code when I change my SIM. Is there a Nokia service centre in Melbourne where the phone can be unlocked?
Also, is it true that if you enter 5 or more incorrect unlock codes, then no matter if the next code is the correct one, the phone will not allow it?
-Thief_
I eventually paid the extra AU$10 and had the phone flashed to the latest firmware (it was still on the original!)
That got rid of my annoying unknown-lock code and I feel really good now!
