3650 3d-outbreak
6 replies · 1,744 views · Started 15 February 2005
hi
i downloaded one game,but the problem is that the game folder contains lots of files and i dont know what to do with em.Most of them have extension .class and theres also a folder named Meta-Inf.my phone is 3650.What do i have to do to install this game or to get it working.
You have opened the *.jar file, maybe even unzipping/unraring it.
Simply send the actual *.jar file to your handset .
im not sure what u are saying.
Anyway when i downloaded it.it was jar and also zip file so i had to unpack it,when i unpacked it then there was lots of unknown files usually theres a sis file which can be installed but with these files i dont know what do to.By the way im using card reader if that helps.
intsfanatic wrote:im not sure what u are saying.
Just send the *.jar file to ur phone. & this games ur refering 2 is a java game hvng name xxxx.jar
The image shows the contents of a *.jar file. Go up one level and send the file you click on to the the phone.
maybe you should try to pack all files in a .jar file. download the packer from net.
