CAN�T SYNC OUTLOOK 2003 EMAIL WITH MY NOKIA 9300 with PCSUITE
2 replies · 5,096 views · Started 15 February 2005
Hi i am trying to sync with pc suite(6.41.6) from Nokia my email from OUTLOOK 2003 with my
nokia 9300( firmware v4.53 // 22-12-2004 // RAE-6 )
and i am not hable to too .... all the rest works and syncs (Calendar and Contacts)
I Always get this
MESSAGE:
Program: MsvServer
Motiv: KERN-EXEC
Number: 3
and the message system is gets closed ...
Can some help with this problem ?
Hi!
I have the same problem - did you get any fix for this?
Regards
Jarmo
cre8or wrote:Hi i am trying to sync with pc suite(6.41.6) from Nokia my email from OUTLOOK 2003 with my
I Always get this
MESSAGE:
Program: MsvServer
Motiv: KERN-EXEC
Number: 3
Try the latest PC Suite from http://www.nokia.com/pcsuite
Uninstall the old one first, then uninstall also "Nokia Connectivity Cable" drivers from Control Panel and its Add/Remove Programs. Reboot. Then install the newer version.
