Where I can Find....?????
5 replies · 1,879 views · Started 17 February 2005
Some program to Convert MP3 (and others) to .WAV MONO?
Its not just that, i need a program to cut the music and/or pass some MP3/OGG to Mono and reduce your bitrate!
the Masterforce say that GSM compression 6.xxx convert MP3 to WAV but I need a link to Download, and other programs more!
Please Help ME!
[QUOTE='[O_pSiCoPAtA]']Some program to Convert MP3 (and others) to .WAV MONO?
Please Help ME![/QUOTE]
There is so many solution 4 that, for example u can use
Advanced WMA Workshop
Acoustica MP3 Mixer
etc
Find more info at:
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]
Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
Apocalypso wrote:There is so many solution 4 that, for example u can use
Acoustica MP3 Mixer
etc
Find more info at:
[CENTER]
[CENTER]
One friend say to me that they doing that:
Converting MP3 to WAV;
EDIT WAV (IF is just to Ringtone), if you dont gone used to ringtone dont need edit);
Convert to MONO;
And after to AMR!
Play in NOkia normal, like rintone and appears like MP3!
Use DBpowerAMP to convert your MP3's to WAV. You can specify before converting if you want it in mono/stereo, what bit rate etc. From there, I use Window's built in Sound Recorder to edit my wav files. After editing, i send it to the phone.
The easiest way to convert to AMR is using Nokia Multimedia convertor from Forum Nokia. However, its a hefty download (17MB). I havent tried it, so i dont know abt the quality.
dbpoweramp can be found at - www.dbpoweramp.com
Forum Nokia (convertor) - forum.nokia.com
im using WAV (ADPCM) with 22khz, Stereo and i thing that has 177kbit/s, its the same size MP3/Ogg!
The sound to be ringtone its very nice!
Acoustica MP3 Mixer
etc
.[/CENTER]
yep, these are good. Just do some price shopping first - Deprice, Froogle, PriceGrabber, Shopping.Com, etc.
I got my copy Of Advanced WMA Workshop at 15% off from here
http://www.deprice.com/advancedwmaworkshop.htm
not bad, ain't it? Look on eBay, too, if you are goint go buy it.
