Will formatting the phone erase my contacts list ? Please need urgent reply.
Never used the *#7370# command and I'm a little afraid.
URGENT !!! *#7370# question
geodor wrote:Will formatting the phone erase my contacts list ? Please need urgent reply.
U will lose all user data, formating delate all data in ur phone mem and restor new files from ROM.
U need to make a good backup first..
More info at:
[CENTER]
Get more guides and advice at:
www.symbian-freak.com[/CENTER]
[CENTER]
Symbian Freak introduces various researches for symbian users like:
Error Fixes, Modding, Guides, Tutorials and offcourse a detailed forum with professional support.
To get more out of your favourite device, visit the website.[/CENTER]
hi
You can try the command *#7780# which is Normal Reset.....
Normal Reset of Series 60 devices is done using ( *#7780# ), this normal reset restores ini files from rom but preserves user data (photos, 3rd party apps etc).
Deep Reset of Series 60 devices is done using ( *#7370# ), which reformats completely the C: drive and also all applications, files stored on this drive will be lost and clean default files will be rewritten
keep rocking....... 😊
JA
hi
JA
You can use smartvcard from symbianware to backup your contacts and can save it to your memory card then retrieve it later wen u done reseting your phone no need to type again manualy you can also download it here click the link!
