Change Your Theme Icons(Application Icon) in 7610/6630/6680 like 6600 !
15 replies · 72,062 views · Started 17 February 2005
First of all , I'm sorry for my bad english , but I'm italian ...
I don't know if anyone already found this trick but I post it again..
How we know in 7610 theme edit , the change icons options misses..BUT!!!!
If you install a FileSystem Browser like FExplorer and follow this istruction you can use a theme with the icons of another one...
1) apply the theme you would like to grub the icons
2) edit this theme changing color palet or goto image or background image (one of this)
3) the point 2 , create a .INI file in c:\system\skins\yourthemedir **(if the theme is in phone memory) or create a .INI file in e:\system\skins\yourthemedir **(if the theme is in memory card)
4) the INI file you found as a name like the folder of the theme , if you look this file you can find a line like the following:
Icons=270501511
5) annotate the number after =
6) with FExplorer go to the folder of the theme you would like to aply and you like to change the icons (c:\system\skins\yourtheme** or e:\system\skins\yourtheme**)
7) Change the extention of the .INI file you find in .TXT , and after that if you have in your phone a text editor use it , otherwise send this file to computer
8) Change the line Icons=3556454 with Icons=the number you annotate at point 5
9) put the file in the same folder it was before (if you use computer)
10) rename the file from .TXT to .INI
11) Close FExplorer
12) Go to theme , and aply the theme
13) Your theme is apply but the icons are the ones you grub from other theme...
It' s to much easy to do rather than explain...
:icon14: :icon14: :icon14:
** yourthemedir is a folder with a strange name like 101f8687ghf564 (IF YOU LOOK INSIDE YOU CAN SEE A FILE WITH THE NAME OF THE THEME , TO CONTROL IF IT'S RIGHT FOLDER), you must search the right folder if you have more themesIt
I have Tried on my theme on 6680
i have tried on 5 themes out of five 2 was mango themes
and i was able to do on 1 Mango theme but not another and rest i was able to do on 2 themes.
i will try again it is little bit hard
is there any way to change or edit the file in the Phone only.
I tried via Card Reader and it work out and found it Eassiest Way.
I am going to make a sticky.
Guys anyone got AFA argentina football association theme for N7610 or any other argentinian players theme or any site where i can download. please post or send to my e-mail ([email protected])
mirco.p wrote:First of all , I'm sorry for my bad english , but I'm italian ...
Icons=270501511
11) Close FExplorer
Wow this really works!!! =) I appreciate the info dude! Kudos for that! =)
sorry but cant do it..
icons= ?
delete which part
i have tried several attemps
help and thanks
can you help me for nokia 7610 themes studio, how to get tpf files?
Wirelessly posted (Nokia7610/2.0 (4.0441.0) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0)
Icons=270501511
11) Close FExplorer
NAYAN
Icons=270501511
11) Close FExplorer
NAYAN
[B]sir,ur msge about chnging theme icons is really fantastic, i apprecitate for the master mind. sir ia hav a doubt. iam able to grub icons from a theme to another, BUT AT TIMES THE THEME FROM WHICH I WANT TO GRUB ICONS DOESN'T SHOW THE . INI FILE. THEN HOW TO FIND WHICH FILE IS LINKED TO THE THEME. also at times the destination theme doesnt show the .INI file then how to find the icon numbers
thnk u plse help me kichaz.
my email --
[email][email protected][/email] -----------x-------------x----------------
Icons=270501511
11) Close FExplorer
Hai bro..I not realy undrstand how to make this trick..Can anyone explain this with picture ok..Thanks for helping me regard..
