Hi all,
Is there a way to remove the annoying message of outlook, that a program tries to use the local contact database (virus/worm protecion)
Everytime I put the phone in the cradle/use bluetooth, outlook asks me to give the program permission for a short while.
Does anyone know how to avoid this?
Thanks in advance,
Jan-Willem
comfirm.be
There is a way!
http://www.contextmagic.com/express-clickyes/
However viruses and worms will get through easier, but you do get rid of the warning
Delta737 wrote:There is a way!
http://www.contextmagic.com/express-clickyes/However viruses and worms will get through easier, but you do get rid of the warning
Thx Delta,
But is there also a way without the need to install an extra program. eg. Registry changing, ini file,...
Regards,
Jan-Willem
comfirm.be
No other way (besides Nokia changing PC Suite to work so that it doesn't cause this dialog to pop up; presumably needs some cooperation from Microsoft's side to allow this).
